Configure RIPng on Ethernet ports and VLANs so that they can participate in RIPng routing.
RIPng does not operate on a port or VLAN until you enable it both globally and on the port or VLAN.
Assign an IP address to the port or VLAN.
Configure RIPng and enable it globally.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#interface vlan 22
Switch:1(config-if)#ipv6 rip
Switch:1(config-if)#ipv6 rip enable
Switch:1(config-if)#show ipv6 rip interface
Total RIPng interfaces: 2
RIPng Interface - GlobalRouter
IFINDX COST POISON SEND ADMIN OPER
STATUS DEFAULT STATUS STATUS
257 (2/2 ) 2 disable disable enable enable
2070 (22 ) 5 disable disable enable disable
2 out of 2 Total Num of RIPng interfaces displayed
The following table defines parameters for the ipv6 rip command.
Variable |
Value |
<1-4059> |
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. This variable applies only to VLAN interfaces, not ports. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
