This procedure only applies to the VSP 7400 Series.
- Enable multicast on the boundary nodes.
- Configure Multiprotocol Label Switching Virtual Private Network (MVPN) on the boundary nodes, for layer 3 VSN.
- Configure the same policies as the boundary node on the peer boundary nodes.
Perform this procedure to configure IS-IS Multi-area SPB IPv4 routed multicast redistribution on a specific Virtual Router Forwarding (VRF) instance on the switch.
Configuring IS-IS Multi-area SPB IPv4 routed multicast redistribution for home to remote direction on VRF VRF1:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router vrf VRF1 Switch:1(router-vrf)#isis multi-area ip redistribute routed-multicast home-to-remote Switch:1(router-vrf)#isis multi-area ip redistribute routed-multicast home-to-remote route-map test Switch:1(router-vrf)#isis multi-area ip redistribute routed-multicast home-to-remote enable Switch:1(router-vrf)#show isis multi-area ip redistribute routed-multicast home-to-remote vrf VRF1 ======================================================================================= ISIS Multiarea Redistribute List for routed multicast - VRF VRF1 ======================================================================================= DIRECTION ENABLE RPOLICY --------------------------------------------------------------------------------------- home-to-remote TRUE test --------------------------------------------------------------------------------------- Switch:1(router-vrf)#exit Switch:1(config)#isis multi-area ip apply redistribute routed-multicast home-to-remote vrf VRF1
The following table defines parameters for the isis multi-area ip redistribute routed-multicast and the isis multi-area ip apply redistribute routed-multicast commands.
Variable | Value |
enable |
Enables IPv4 routed multicast redistribution on the VRF instance. |
home-to-remote |
Specifies the IPv4 routed multicast redistribution configuration for home to remote direction. |
remote-to-home |
Specifies the IPv4 routed multicast redistribution configuration for remote to home direction. |
route-map WORD<1-64> |
Specifies the name of the route policy. |
vrf WORD<1-16> |
Specifies the multicast routing redistribution configuration for specific VRF instance. |
