View all of the ACE IP entries associated with an ACL.
- Click Advanced Filters (ACE/ACLs).
- Click the ACL tab.
- Select the appropriate ACL.
- Click IP.
IP field descriptions
Use the data in the following table to use the IP tab.
Name |
Description |
AclId |
Shows the ACL IP ID. |
AceId |
Shows the ACE ID. |
SrcAddrOper |
Shows the operators for the ACE IP source address. |
SrcAddrIpAddr |
Shows the IP source address to match from the IP header. |
SrcAddrOperMaskRange |
Shows the IP mask value if SrcAddrOper is set to mask, or the highest IP address if SrcAddrOper is set to range. |
DstAddrOper |
Shows the operators for the ACE IP destination address. |
DstAddrIpAddr |
Shows the IP destination address to match from the IP header. |
DstAddrOperMaskRange |
Shows the IP mask value if DstAddrIpAddr is set to mask, or the highest IP address if DstAddrIpAddr is set to range. |
DscpList |
Shows how the 6-bit DSCP parameter from the TOS byte in the IPv4 header encodes PHB information following RFC 2474. |
DscpOper |
Shows the operators for the ACE IP DSCP. |
DscpOperMask |
Shows the mask value in hexadecimal format when the mask option is selected in DscpOper. |
ProtoList |
Shows the IP protocol type from the IP header to match. The range is 0–255. |
ProtoOper |
Shows the operators for the ACE IP protocols. |
Options |
Shows the IP options to match from the IP header. |
OptionsOper |
Shows the logical operator. Any is the only option. |
Fragmentation |
Shows the IP fragmentation bits to match from the IP header. |
FragOper |
Shows the operator for IP fragmentation. |
