Overflow counters consist of IPv6 addresses that are not added to IP Source Guard (IPSG) due to lack of filter resources. Use this procedure to clear the overflow counters for an IPSG port.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
ipv6 source-guard overflow-count clear
show ipv6 source-guard interface gigabitEthernet [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]
show ipv6 source-guard interface enabled
Clear overflow counters on the IPSG port 4/1.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitEthernet 4/1 Switch:1(config-if)#ipv6 source-guard overflow-count clear
Verify the configuration on port 4/1.
Switch:1(config-if)#show ipv6 source-guard interface gigabitEthernet 4/1
Slot/Port  Source Guard  Number of  IPv6  Address
             Mode        address allowed  overflow count
4/1          Enabled           10          0
Optionally view the overflow counters on all IPSG enabled ports.
Switch:1(config-if)#show ipv6 source-guard interface enabled
4/1          Enabled            4           0
3/1          Enabled            9           0
