This procedure does not apply to VSP 8600 Series.
Use this task to view IP address statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IP tab.
- To clear IP statistics, select Clear Stats.
- To clear IP counters, select Clear Counters.
IP Field Descriptions
Use the data in the following table to use the IP tab.
Name |
Description |
InReceives |
Shows the inbound packet statistics. |
InHdrErrors |
Shows the inbound packets with header errors statistics. |
InAddrErrors |
Shows the inbound packets with address errors statistics. |
InUnknownProtos |
Shows the inbound packets with unknown protocols statistics. |
InDiscards |
Shows the inbound packets discarded statistics. |
InDelivers |
Shows the inbound packets delivered statistics. |
OutRequests |
Shows the outbound packet requests statistics. |
OutDiscards |
Shows the outbound packets discarded statistics. |
OutNotRoutes |
Shows the outbound packets with no routes statistics. |
ForwDatagrams |
Shows the forwarded datagram packets statistics. |
ReasmTimeout |
Shows the packet reassembly timeouts statistics. |
ReasmReqds |
Shows the packet reassembly requests statistics. |
ReasmOKs |
Shows the successfully reassembled packets statistics. |
ReasmFails |
Shows the failed reassembled packets statistics. |
FragOKs |
Shows the successfully fragmented packets statistics. |
FragFails |
Shows the failed fragmented packets statistics. |
FragCreates |
Shows the fragments created statistics. |
