This procedure does not apply to VSP 8600 Series.About this task
Use this task to view Fragmented ICMP packet filtering details on a Management Instance.
- To enter User EXEC mode, log on to the switch.
View Fragmented ICMP packet
filtering:
For IPv4:
show mgmt ip icmp [clip | oob | vlan]
For IPv6:
show mgmt ipv6 icmp [clip | oob | vlan]Note
This command does not apply to XA1400 Series.
The following table defines parameters for the show mgmt ip icmp command.
Variable |
Value |
clip |
Displays the IPv4 or IPv6 ICMP information specific to the management CLIP. |
oob |
Displays the IPv4 or IPv6 ICMP information specific to the management OOB. |
vlan |
Displays the IPv4 or IPv6 ICMP information specific to the management VLAN. |
