Use this procedure to monitor the IP multicast route statistics at regular intervals.
Example:
Monitor the IP multicast route statistics for the group IP address 225.0.0.1. In this example, the statistics are monitored at intervals of 5 seconds for a duration of 300 seconds.
The output from monitoring three consecutive intervals is displayed below.
Switch:1>en
Switch:1#monitor ip mroute stats 225.0.0.1
MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec Mon Dec 21 16:12:07 2015
Multicast Stats - GlobalRouter
GroupAddress SourceCounter IngressPackets IngressBytes AverageSize
225.0.0.1 1 4716624 603727872 128
MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec Mon Dec 21 16:12:13 2015
225.0.0.1 1 4767325 610217600 128
MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec Mon Dec 21 16:12:19 2015
Switch:1#
Monitor the IP multicast route statistics for a maximum of 10 group IP addresses. The statistics are monitored at intervals of 5 seconds for a duration of 300 seconds.
Switch:1#monitor ip mroute stats 225.0.0.1,225.0.0.2,225.0.0.3,225.0.0.4,225.0.0.5,225.0.0.6,225.0.0.7,225.0.0.8,225.0.0.9,225.0.0.10
MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec Mon Dec 21 16:22:07 2015
225.0.0.1 1 9532039 1220100992 128
225.0.0.2 1 9532041 1220101120 127
225.0.0.3 1 9532042 1220101248 127
225.0.0.4 1 9532043 1220101376 127
225.0.0.5 1 9532044 1220101632 128
225.0.0.6 1 9532045 1220101760 128
225.0.0.7 1 9532046 1220101888 128
225.0.0.8 1 9532047 1220101888 127
225.0.0.9 1 9532048 1220102016 127
225.0.0.10 1 9532048 1220102144 128
MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec Mon Dec 21 16:22:13 2015
225.0.0.1 1 9582672 1226582016 128
225.0.0.2 1 9582674 1226582144 127
225.0.0.3 1 9582675 1226582272 127
225.0.0.4 1 9582676 1226582400 127
225.0.0.5 1 9582677 1226582656 128
225.0.0.6 1 9582678 1226582784 128
225.0.0.7 1 9582679 1226582912 128
225.0.0.8 1 9582681 1226583040 127
225.0.0.9 1 9582681 1226583040 127
225.0.0.10 1 9582681 1226583168 128
MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec Mon Dec 21 16:22:19 2015
225.0.0.1 1 9625009 1232001152 128
225.0.0.2 1 9625011 1232001280 127
225.0.0.3 1 9625012 1232001408 127
225.0.0.4 1 9625013 1232001536 127
225.0.0.5 1 9625014 1232001792 128
225.0.0.6 1 9625015 1232001920 128
225.0.0.7 1 9625016 1232002048 128
225.0.0.8 1 9625018 1232002176 127
225.0.0.9 1 9625019 1232002304 127
225.0.0.10 1 9625018 1232002304 128
Switch:1#
Variable definitions
Use the data in the following table to use the monitor ip mroute stats command.
Variable |
Definition |
WORD<7-160> {A.B.C.D[,E.F.G.H][,...]} |
Specifies the multicast group IP address for which to monitor statistics. The group IP address is in one of the following formats: a single IP address or a series of IP addresses, up to a maximum of 10. |
