Use square-Split MultiLink Trunking (SMLT) to form an SMLT aggregation group. In a square configuration, enable square-SMLT globally on each of the four switches.
Important
The following configuration also activates full-mesh configurations.
This procedure is supported only on a DvR Controller. It is not supported on a DvR Leaf node.
Clear this check box if you want to disable square-SMLT globally.
