Enable FHS globally for ND inspection to work.
Use this procedure to enable Neighbor Discovery inspection on a port
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
ipv6 fhs nd-inspection enable
