This procedure does not apply to VSP 8600 Series.
Use this task to view IP ICMP statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IP-ICMP tab.
- To clear IP statistics, select Clear Stats.
- To clear IP counters, select Clear Counters.
IP-ICMP Field Descriptions
Use the data in the following table to use the IP-ICMP tab.
Name |
Description |
InMsgs |
Shows the inbound messages statistics. |
InErrors |
Shows the inbound errors statistics. |
InCsumErrors |
Shows the inbound checksum errors statistics. |
InDestUnreachs |
Shows the inbound destination unreachable statistics. |
InTimeExcds |
Shows the inbound time exceeded statistics. |
InParmProbs |
Shows the inbound parameter problems statistics. |
InSrcQuenchs |
Shows the inbound source quenchs statistics. |
InRedirects |
Shows the inbound redirects statistics. |
InEchos |
Shows the inbound echos statistics. |
InEchoReps |
Shows the inbound echo replies statistics. |
InTimestamps |
Shows the inbound timestamps statistics. |
InTimestampsReps |
Shows the inbound timestamp replies statistics. |
InAddrMasks |
Shows the inbound address masks statistics. |
InAddrMaskReps |
Shows the inbound address mask replies statistics. |
OutMsgs |
Shows the outbound messages statistics. |
OutErrors |
Shows the outbound errors statistics. |
OutDestUnreachs |
Shows the outbound destination unreachable statistics. |
OutTimeExcds |
Shows the outbound time exceeded statistics. |
OutParmProbs |
Shows the outbound parameter problems statistics. |
OutSrcQuenchs |
Shows the outbound source quenchs statistics. |
OutRedirects |
Shows the outbound redirects statistics. |
OutEchos |
Shows the outbound echos statistics. |
OutEchoReps |
Shows the outbound echo replies statistics. |
OutTimestamps |
Shows the outbound timestamps statistics. |
OutTimestampReps |
Shows the outbound timestamps replies statistics. |
OutAddrMasks |
Shows the outbound address masks statistics. |
MsgInType0 |
Shows the inbound Type0 messages statistics. |
MsgOutType8 |
Shows the outbound Type8 messages statistics. |
