Create an MSDP peer to establish a peer relationship between the local MSDP enabled router and a
            peer in another domain.
Important
Do not enable more than 20 active peers.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip msdp peer 21.0.0.2 Switch:1(config)#ip msdp peer 21.0.0.2 enable Switch:1(config)#ip msdp peer remote-as 1
Variable definitions
The following table defines parameters for the ip msdp peer command.
 Variable  |
 Value  |
 {A.B.C.D}  |
 Specifies the MSDP peer IP address.  |
 WORD<0-11>  |
 Specifies the AS number of the MSDP peer, 0-65535 (2-Byte AS) 0-4294967295 (4-Byte AS).  |
