Perform this procedure to view the amount of switch capacity and PoE power being saved on the units.
- Click Energy Saver.
- Click the Energy Savings tab.
Energy Savings field descriptions
| Name | Description |
| UnitIndex | Specifies the unit number. |
| UnitSavings(1/10 watts) | Specifies the amount of switch capacity power being saved on the specific unit. |
| PoeSavings(1/10 watts) | Specifies the amount of PoE power being saved on the specific unit. |
