Configure CP Limit functionality to protect the switch from becoming congested by an excess of data flowing through one or more ports.
- In the Device Physical View tab, select a port.
- In the navigation pane, expand Configuration > Edit > Port.
- Click General.
- Click the CP Limit tab.
- Select the AutoRecoverPort check box.
- Click Apply.
CP Limit field descriptions
Use the data in the following table to use the CP Limit tab.
Name |
Description |
AutoRecoverPort |
Activates or disables auto recovery of the port from action taken by CP Limit or link flap features. The default value is disabled. |
