Use the following procedure to configure the Ethernet MSTP MSTI parameters on a port.
Configure Ethernet MSTP MSTI:
Switch(config-if)# spanning-tree mstp msti 62 priority 32
Use the data in the following table to use the spanning-tree mstp msti <1-63> command.
| Variable | Value |
| <1–63> | Specifies the instance ID. |
| cost <1–200000000> | Configures the path cost for the port |
| force-port-state enable | Enables MSTI learning for the port. |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
| priority <0–240> | Configures the priority for the port. Enter the priority value (0–240) as increments of 16. |
