This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the IS-IS Multi-area SPB virtual node parameters like nick-name, system ID, and system name in the home or remote area.
Configuring the IS-IS Multi-area SPB virtual node in the home area:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router isis Switch:1(config-isis)#area-vnode nick-name 0.82.40 Switch:1(config-isis)#area-vnode sys-name SwitchC Switch:1(config-isis)#area-vnode system-id 1222.3300.0000
Configuring the IS-IS Multi-area SPB virtual node in the remote area:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router isis remote Switch:1(config-isis)#area-vnode nick-name 0.82.60 Switch:1(config-isis)#area-vnode sys-name SwitchA Switch:1(config-isis)#area-vnode system-id 1222.3311.2222
What to do next
To verify the configuration, see Display IS-IS Area Virtual Node Configuration.
The following table defines parameters for the area-vnode command.
Variable | Value |
nick-name x.xx.xx |
Specifies a nickname for the IS-IS SPBM Multi-area SPB instance. The value is 2.5 bytes in the format x.xx.xx. |
sys-name WORD<0-255> |
Specifies the name of the system. |
system-id xxxx.xxxx.xxxx |
Specifies the IS-IS Multi-area SPB virtual node system ID. |
