Use the following procedure to create a static ARP entry.
Static multicast ARP entries are not supported for NLB Unicast or NLB Multicast
operations.
- In the navigation tree,
expand the following folders: .
- Click IP.
- Click the ARP tab.
- Click Insert.
- In the NetAddress field, type the IP address.
- Click Port.
- In the dialog box,
select the interface.
- Click OK.
- In the PhysAddress field, type the MAC address.
- Click Insert.
