You must create a Management Instance to gain access to specific management applications. After you create the Management Instance, you can add an IP address to it and configure route redistribution to advertise reachability of the Management Instance to the rest of the network.
The Management Instance supports different management interface types. When you create the Management Instance, you specify the interface type and the switch automatically creates the appropriate instance ID for that type.
A management VLAN is used for Layer 2 deployments. In a Layer 3 routing or Fabric deployment, use a management CLIP. For Out-of-band Management, use a management OOB.
Each Management Instance supports a IPv4 and IPv6 (global scope) management address for use by management applications.
enable
configure terminal
mgmt clip [vrf WORD<1–16>]
If you do not specify a VRF, the management CLIP uses the GRT. You cannot use mgmtrouter as the VRF.
OR
mgmt oob
OR
mgmt vlan <2-4059>
enable
Create and enable a Management CLIP:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#mgmt clip Switch:1(mgmt:clip)#enable
Create and enable a Management OOB:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#mgmt oob Switch:1(mgmt:oob)#enable
Create and enable a Management VLAN:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#mgmt vlan 20 Switch:1(mgmt:vlan)#enable
