Perform this procedure to view information about the USB port on the switch.
This information may not apply to your hardware model. For more information about your model features, see your hardware documentation.
- In the Device Physical View, select the USB port.
- Click USB Port.
- Click the General tab.
General field descriptions
Use the data in the following table to use the General tab.
Name |
Description |
UsbStatus |
Displays the current status of USB storage: either present or notPresent. |
UsbDescription |
Displays a description of the USB storage. |
