This procedure only applies to VSP 8600 Series.
Use this procedure to control whether or not to supply power to specific slots that contain either switch fabric modules or input/output modules. By default, power is available to all slots.
After enabling power to specific input/output module slots, you can also configure the priority in which they are powered on. For more information, see Configure Slot Priority.
This feature is not available for hardware platforms with fixed configurations. It is only available for platforms where the user can install modules in slots.
