This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the area virtual node parameters like system name, system ID, and nickname on the remote Intermediate-to-Intermediate-System (IS-IS) instance.
- Select IS-IS Remote.
- Select the Area VNode tab.
- Configure the parameters.
- Select Apply.
Area VNode Field Descriptions
Use the data in the following table to use the Area VNode tab.
Name | Description |
VNodeNickName |
Specifies the nickname of the virtual node on remote IS-IS instance. |
VNodeSysId |
Specifies the system ID of the virtual node on remote IS-IS instance. |
VNodeSysName |
Specifies the system name of the virtual node on remote IS-IS instance. |
