View the OSPF area information.
View the OSPF area information:
Switch:1>enable
Switch:1#show ip ospf area
OSPF Area - GlobalRouter
AREA_ID STUB_AREA NSSA IMPORT_SUM ACTIVE_IFCNT NSSA TRANSLATOR NSSA TRANSLATOR NSSA TRANSLATOR NSSA TRANSLATOR
ROLE STATE STABILITY INTERVAL EVENTS
0.0.0.0 false false true 0 candidate disabled 40 0
STUB_COST INTRA_AREA_SPF_RUNS BDR_RTR_CNT ASBDR_RTR_CNT LSA_CNT LSACK_SUM
0 0 0 0 0 0
Variable definitions
The following table defines parameters for the show ip ospf area command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF by name. |
vrfids WORD<0-512> |
Specifies a range of VRF IDs. |
