Use VLACP as an extension to LACP for end-to-end failure detection. Enable or disable VLACP globally to reset the port level configuration. The default is disabled.
Important
Changes you make at the global level override and reset all port level settings.
enable
configure terminal
vlacp enable
no vlacp enable
Enable VLACP globally:
Switch:1(config)# vlacp enable
