This procedure shows how to configure PIM and IGMP Snooping in
an SMLT environment. The configuration steps show how to enable multicast,
and then configure the usual PIM and IGMP Snooping related VLANs and
global attributes. It includes steps to configure the following:
SPBM must not be enabled on the vIST peers or any router participating
in the PIM network.
- In the navigation pane,
expand the folders.
- Click the Boot Config tab.
- Clear the EnableSpbmConfigMode to disable the boot flag.
The system responds with these messages:
Warning:
Please save the configuration and reboot the switch for this to take
effect.
Warning:
Please carefully save your configuration file before rebooting the
switch. Saving configuration file when spbm-config-mode is changed
to disable, removes SPBM configurations from the configuration file.
- Click Apply.
- Save the configuration,
and then reboot the switch.
Important
Any change to the EnableSpbmConfigMode boot flag requires a reboot for
the change to take effect.
- Configure the SMLT MLT:
- Expand the following
folders: .
- Click the MultiLink/LACP Trunks tab.
- Click Insert.
- In the Id box,
type the ID number of the MLT.
- In the PortMembers box, click the (...) button.
- In the Port Editor: PortMembers dialog box, select the desired ports.
- Click Ok
- Click Insert.
The switch adds the SMLT MLT to the MultiLink/LACP Trunks tab in
the MLT_LACP box.
Configure the vIST
MLT:
Repeat steps 6a to 6g to
configure the MLT.
Click MltVistEnable to enable Simplified vIST.
The MltVistEnable field enables Simplified vIST and
is only available when the EnableSpbmConfigMode boot flag is disabled.
Click Insert.
- Create the vIST VLAN:
folders:
In the Basic tab, click Insert.
- In the Id box,
enter an unused VLAN ID, or use the ID provided.
- In the MstpInstance box, click the down arrow, and then choose an MSTI instance from
the list.
- In the Type box,
select byPort.
- Click OK.
- Click Insert.
- Select the vIST VLAN
from the list of VLANs, and then click IP.
- Click Insert.
- Configure the IP address
for the vIST VLAN.
- Repeat Step 8 to create
an SMLT VLAN
and assign the SMLT MLT ID to it. Do not use the vIST MLT ID.
- Configure PIM or IGMP
Snooping on the SMLT VLAN:
- To enable PIM, select
the SMLT VLAN from the list of VLANs and click . Select Enable and
click Apply.
- To enable IGMP Snooping,
select the SMLT VLAN from the list of VLANs and click . Select SnoopEnable and click Apply.
- Configure PIM on the SMLT VLAN:
click Apply.
- Click to enable PIM globally.
- Select the Enable check
box, and then click Apply.
