This procedure does not apply to VSP 8600 Series.
Use this task to view TCP statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IP/IPv6 TCP tab.
IP/IPv6 TCP Field Descriptions
Use the data in the following table to use the IP/IPv6 TCP tab.
Name |
Description |
IPVersion |
Shows the IP address version as ipv4 or ipv6. |
ActiveOpens |
Shows the active open TCP connections statistics. |
PassiveOpens |
Shows the passive open TCP connections statistics. |
AttemptFails |
Shows the TCP connection attempt failures statistics. |
EstabResets |
Shows the TCP connection esablished resets statistics. |
InSegs |
Shows the input segments statistics. |
OutSegs |
Shows the output segments statistics. |
RetransSegs |
Shows the retransmit segments statistics. |
InErrs |
Shows the input checksum errors statistics. |
OutRsts |
Shows the output resets statistics. |
InCsumErrors |
Clear |
Specifies to clear the statistics. Default is false. |
