This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the Multi-area SPB layer 2 multicast redistribution for specific I-SID value(s) in the home area.
- Select MultiArea.
- Select the L2 MC Redist Home ISID tab.
- Select Insert.
- In the I-sid field, type the I-SID value.
- Select Enable.
- Optional: In the PolicyName field, type the name of the redistribution policy.
- Select Insert.
L2 MC Redist Home ISID Field Descriptions
Use the data in the following table to use the L2 MC Redist Home ISID tab.
Name | Description |
I-sid |
Specifies the I-SID value. |
Enable |
Enables layer 2 multicast redistribution for specific I-SID value in the home area. |
PolicyName |
Specifies the name of the redistribution policy. |
