After you enable or disable certain modes and functions, you need to save the configuration and restart the switch for your change to take effect. This section lists parameters and indicates if they require a switch restart.
The following table lists parameters you configure in the CLI using the boot config flags command. For information on system flags and their configuration, see Configure Boot Flags.
Flag support can vary across hardware models.
CLI flag |
Restart |
advanced-feature-bandwidth-reservation Note:
Exception: Only supported on VSP 7400 Series and XA1480. |
Yes |
block-snmp |
No |
debug-config |
Yes |
debugmode |
Yes |
dvr-leaf-mode Note:
The switch does not require a restart when you enable the dvr-leaf-mode flag, as long as there is no unsupported configuration on the switch. |
No |
enhancedsecure-mode |
Yes |
factorydefaults |
Yes |
flow-control-mode Note:
Exception: Not supported on VSP 8600 Series. |
Yes |
ftpd |
No |
ha-cpu Note:
Exception: Only supported on VSP 8600 Series. |
Yes, the standby CPU restarts automatically. Modifying this flag does not require a system restart. |
hsecure |
Yes |
linerate-directed-broadcast Note:
Exception: Only supported on VSP 4450 Series. |
Yes |
ipv6-egress-filter Note:
Exception: Not supported on VSP 8600 Series or XA1400 Series. |
Yes |
ipv6-mode Note:
Exception: Not supported on VSP 4450 Series, VSP 8600 Series, or XA1400 Series. |
Yes |
logging |
No |
nni-mstp Note:
Yes |
reboot |
No |
rlogind Note:
No |
savetostandby Exception: Only supported on VSP 8600 Series. |
No |
spanning-tree-mode |
Yes |
spbm-config-mode |
Yes |
sshd |
No |
telnetd |
No |
tftpd |
No |
trace-logging |
No |
urpf-mode Note:
Yes |
verify-config |
Yes |
vrf-scaling |
Yes |
vxlan-gw-full-interworking-mode Exception: Only supported on VSP 7200 Series, VSP 7400 Series , VSP 8200 Series, and VSP 8400 Series. |
Yes |
