Enable VRRP global variables to enable the VRRP function.
- In the navigation pane, expand the following folders: .
- Click VRRP.
- Click the Globals tab.
- Configure the required features.
- Click Apply.
Globals field descriptions
Use the data in the following table to use the Globals tab.
Name |
Description |
NotificationCntl |
Indicates whether the VRRP-enabled router generates SNMP traps
for events.
The default is enabled. |
PingVirtualAddrEnable |
Configures whether this device responds to pings directed to a virtual router IP address. The default is enabled. |
