Configuring a node as a DvR Controller enables DvR globally on that node.
Perform this procedure to create a DvR domain with the domain ID that you specify, and configure the role of the node as the Controller of that domain. A Controller can belong to only one DvR domain.
For a node to perform the role of both a Controller and a Leaf within a DvR domain, you must configure it as a Controller.
Ensure that you configure IP Shortcuts on the node. This is necessary for proper functioning of the node as a DvR Controller.
Ensure that the dvr-leaf-mode boot flag is disabled on the node.
To verify the setting, enter show boot config flags in Privileged EXEC mode.
Configure a node as a DvR Controller:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#dvr controller 5 Switch:1(config)#show dvr ================================================================== DVR Summary Info ================================================================== Domain ID : 5 Domain ISID : 16678219 Backbone ISID : 16678216 Role : Controller My SYS ID : 00:bb:00:00:81:21 Operational State : Up GW MAC : 00:00:5e:00:01:25 InjectDefaultRouteDisable(GRT) : Disabled
Variable definitions
Use the data in the following table to use the dvr controller command.
Variable |
Value |
<1-255> |
Specifies the domain ID of the DvR domain that the controller belongs. |
