The following table defines parameters for the show isis spbm ip-multicast-route command.
| Variable | Value |
| all | Displays all IP Multicast over Fabric Connect route information. |
| detail | Displays detailed IP Multicast over Fabric Connect route information. |
| group{A.B.C.D} | Displays information on the group IP address for the IP Multicast over Fabric Connect route. |
| vlan<1-4059> | Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. |
| vrfWORD<1–16> | Displays IP Multicast over Fabric Connect route information by VRF. |
| vsn-isid<1–16777215> | Displays IP Multicast over Fabric Connect route information by I-SID. |
The following table defines parameters for the show isis spb-mcast-summary command.
| Variable | Value |
| count | Displays the total number of SPB multicast entries. |
| host-nameWORD<0–255> | Displays the IP Multicast over Fabric Connect summary information by host-name. |
| lspid<xxxx.xxxx.xxxx.xx-xx> | Displays the IP Multicast over Fabric Connect summary information by LSP ID. |
