Configure PoE usage threshold and device type settings, and enable Fast PoE and Perpetual PoE globally on a switch.
Important
After you enable Fast PoE or Perpetual PoE or both, you must save the running configuration file.
If Fast PoE or Perpetual PoE are enabled and you change any other global or port-specific PoE settings, you must resave the running configuration file.
- Select Chassis.
- Select the PoE tab.
- Configure the fields as required.
- Select Apply.
PoE Field Descriptions
Use the data in the following table to use the PoE tab.
Name |
Description |
Power(watts) |
Specifies the nominal power of the Power Sourcing Entity expressed in Watts. |
OperStatus |
Specifies the operational status of the main Power Sourcing Entity. |
ConsumptionPower(watts) |
Specifies the measured usage power expressed in Watts. |
UsageThreshold% |
Configures the usage threshold in percent for comparing the measured power and initiating an alarm if the threshold is exceeded. |
PoweredDeviceDetectType |
Configures the mechanism used to detect powered ethernet devices attached to a powered ethernet
port. The options are:
PowerPresent |
Specifies the current power source present on the switch. Available power sources are AC and DC. A value of acOnly indicates that the only power supply is AC. A value of dcOnly indicates that the only power supply is DC. A value of acDc indicates that the two power supplies, AC and DC are supplying power. |
FastPoeEnable Note:
Exception: only supported on VSP 4900 Series. |
Enables Fast PoE on the switch. The default is disabled. |
PerpetualPoeEnable Note:
Enables Perpetual PoE on the switch. The default is disabled. |
