This procedure only applies to VSP 4900 Series.
Configure all of the ports on an installed Versatile Interface Module (VIM) to operate at the same speed.
Some VIMs must operate with all ports at the same speed, while others can operate with ports at different speeds. For more information, see VOSS Release Notes. The sys vim-speed command is supported only on VIMs that must operate with all ports at the same speed. An error message displays if you run the command on an unsupported VIM.
Install the VIM before performing this procedure.
Use this procedure to configure the speed of all ports in a multi-port VIM to operate at either 10 Gbps or 25 Gbps.
The following table defines parameters for the sys vim-speed command.
Variable |
Value |
10000 | 25000 |
Configures all ports in a multi-port VIM to operate at either 10 Gbps or 25 Gbps. The default is 25 Gbps. |
