Configure a node to perform the role of either a Controller or a Leaf, within the DvR domain.
Important
For DvR Leaf Configuration only:
You must enable the dvr-leaf-mode boot flag before you configure a node as a DvR Leaf node. Navigate to . On the Boot Config tab, select EnableDvrLeafMode.
Ensure that you save the current configuration on the switch, before you enable the flag. Enabling the flag removes all non-DvR configuration on the switch.
Use the data in the following table to use the Globals tab.
Field |
Descriptions |
DomainId |
Uniquely identifies the domain that the node belongs to. The range for a Controller or a Leaf is 1 to 255. Set to 0 if is not configured. |
Role |
Specifies the role of the node in the domain, that is, either a Controller or a Leaf. |
Enable |
Specifies whether DvR is enabled on the node. Configuring a Controller or Leaf sets this parameter to true. |
DomainIsid |
Uniquely identifies the domain I-SID that the node belongs to. 0 indicates that is not configured. |
BackboneIsid |
Uniquely identifies the backbone I-SID that the node belongs to. The valid backbone I-SID is 16678216. It is set to 0 if is not configured. |
GatewayMac |
Specifies the Gateway MAC address used by all Domains. |
InbandMgmtIp Note:
Exception: not supported on VSP 8600 Series or XA1400 Series. |
Specifies the In-band Management IP address configured under IS-IS. You can use this IP address to manage the node, irrespective of whether DvR is enabled on it. |
InjectDefaultRouteDisable |
Specifies whether injection of default routes is disabled on the Controller in the domain. By default, Controllers inject default routes into the domain so that all Leaf nodes in the domain learn these routes with the next hop as the Controller that advertised it. Selecting this field disables this behavior. |
VirtualIstLocalAddr |
Specifies the local IP address of vIST, if vIST is configured on a Leaf. vIST cannot be configured on a Controller. |
VirtualIstLocalMask |
Specifies the local subnet mask of vIST, if vIST is configured on a Leaf. vIST cannot be configured on a Controller. |
VirtualIstPeerAddr |
Specifies the peer IP address of vIST, if vIST is configured on a Leaf. vIST cannot be configured on a Controller. |
VirtualIstClusterId |
Specifies the cluster ID of vIST, if vIST is configured on a Leaf. vIST cannot be configured on a Controller. Set to 0 if vIST is not configured. |
VirtuaIIstIsid |
Specifies the I-SID if vIST is configured. |
OperState |
Specifies the operational state of the node. |
