The implementation of ACL filters is similar in all switches but there are some differences as summarized in the following tables.
The InVSN Filter shares the port-based groups in the following table.
VSP 4450 Series |
VSP 4900 Series VSP 7200 Series VSP 8200 Series VSP 8400 Series |
VSP 7400 Series |
VSP 8600 Series |
XA1400 Series |
If you enable Application Telemetry, IPv6 security filter commands and configurations are blocked and not available. |
If you enable Application Telemetry, IPv6 security filter commands and configurations are supported. |
Application Telemetry and IPv6 filters are not supported |
All switches use a filter group as memory to store filter rules. The number of filter groups used can differ: |
The switch supports four separate ingress filter groups:
The switch supports two ingress filter groups, where each group is shared by two filter types:
The switch supports the following ingress filter group:
The switch supports one ingress filter group with two filter types:
For each ingress packet, a parallel search is performed on each of the four filter groups. |
For each ingress packet, a parallel search is performed on each of the two filter groups. |
For each ingress packet, a search is performed on the filter group. |
Filter |
VSP 4450 Series |
VSP 7400 Series |
VSP 8600 Series |
XA1400 Series |
Can match both port-based and VLAN-based ACL/ACE |
Regardless of the type of matching ACEs (Security or QoS), the action of either the highest priority matching ACE or the default action will be performed. |
Port-based ACLs have precedence over VLAN-based ACLs. If the matching ACEs are of the same type (both Security or both QoS), then the VLAN-based ACL/ACE is ignored. |
Port-based ACLs have precedence over VLAN-based ACLs. If a packet matches both a Port-based and a VLAN-based ACL, then the VLAN-based ACL is ignored. |
Port-based ACLs have precedence over VLAN-based ACLs. If a packet matches both a Port-based and a VLAN-based ACL, then the VLAN-based ACL is ignored. Security ACEs have precedence over QoS ACEs. If packets match a Security and a QoS ACE, only the Security action is applied, the QoS action is ignored |
Filter |
VSP 4450 Series |
VSP 7200 Series VSP 8200 Series |
VSP 4900 Series VSP 7400 Series VSP 8400 Series |
VSP 8600 Series |
XA1400 Series |
ACE ID ranges supported |
Security ACEs: 1–1000 QoS ACEs: 1001–2000 (IPv4 filters only) |
IPv4 filters: Security ACEs: 1–1000 QoS ACEs: 1001–2000 IPv6 filters: ACEs: 1–2000 support both security and QoS actions |
ACEs: 1-1000 support both security and QoS actions. |
redirect-next-hop support |
Supported in both the Global Routing Table and VRF contexts. |
Supported in the Global Routing Table only. |
VSP 4450 Series |
VSP 7400 Series |
VSP 8600 Series |
XA1400 Series |
Configuring an ACE with the ARP operation qualifier is supported for OutPort ACLs. |
Configuring an ACE with the ARP operation qualifier is not supported for OutPort ACLs. |
Configuring an ACE with the ARP operation qualifier is supported for OutPort ACLs The Egress filters do not apply to the mirrored packets. |
VSP 4450 Series |
VSP 7400 Series |
VSP 8600 Series |
XA1400 Series |
Supports Viewing ACL Statistics by the ACE type Security and QoS. |
Supports Viewing ACL Statistics by the ACE type QoS. |
For QoS scaling and filter scaling information, see VOSS Release Notes.
