clear counters vpls
clear counters vpls [vpls_name | all]
Description
Clears all VPLS counters for the specified vpls_name.
Syntax Description
vpls_name Identifies the VPLS within the switch (character string)
all Specifies all VPLS VPNs.
Default
N/A.
Usage Guidelines
This command clears all VPLS counters for the specified vpls_name. If the optional all keyword is specified, all packet and byte counters for all VPLS VPNs are cleared.
This example clears all VPLS counters for the specified VPLS:
clear counters vpls myvpls
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support this feature as described in in the Switch Engine v33.2.1 Licensing Guide document.
