show mpls rsvp-te
show mpls rsvp-te
Description
Displays displays summary configuration and status information for RSVP-TE.
Syntax Description
Default
N/A.
Usage Guidelines
This command displays summary configuration and status information for RSVP-TE. The parameters displayed include:
  • Global status of RSVP-TE.
  • Configured standard LSP timer values.
  • Configured rapid-retry LSP timer values.
  • RSVP-TE VLANs.
The following command shows the summary configuration and status information for RSVP-TE:
# show mpls rsvp-te
RSVP-TE Admin Status  : Enabled
RSVP-TE Oper Status   : Enabled
LSP Standard-Retry Timers
Delay-Interval  : 30 seconds
Decay-Rate      : 50 %
Retry-Limit     : unlimited
LSP Rapid-Retry Timers
Delay-Interval  : 500 milliseconds
Decay-Rate      : 50 %
Retry-Limit     : 10
RSVP-TE VLANs  : vlan1
: vlan2
: vlan3
This command was first available in ExtremeXOS 11.6
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.2.1 Licensing Guide document.
