This command configures PoE port-level classification
power-up mode for Extreme Networks PoE devices that do not support 802.3bt when
connecting to switches with 60W/90W PoE ports. ExtremeSwitching platforms
support per-port basis configuration.
Syntax Description
classification
Classification power-up mode.
ports
Specifies the port.
port_list
Port list separated by a comma or - .
Default
Depends on the maximum classification level supported by the platform. For
example, the 5720 Series has a default classification level of 802.3bt-type4, while
5320 Series has a default classification level of 802.3at.
Usage Guidelines
This command restores port-level classification power-up mode to default based on
port type.
# show inline-power configuration ports 20-26
Port Config Operator Limit Priority Detection Classification Label
20 Enabled 60000 mW Low 802.3af-only 802.3pre-bt N
21 Enabled 60000 mW Low 802.3af-only 802.3bt-type3 N
22 Enabled 60000 mW Low 802.3af-only 802.3bt-type3 N
23 Enabled 45000 mW Low 2-point legacy-and-802.3af 802.3bt-type3 N
24 Enabled 60000 mW Low 802.3af-only 802.3at N model name-port10
25 Enabled 90000 mW Low 4-point legacy-and-802.3af 802.3pre-bt N
26 Enabled 90000 mW Low 802.3af-only 802.3bt-type3 N
This command was first available in ExtremeXOS 31.3.
Platform Availability
This command is available on:
PoE+
ExtremeSwitching
5420F-8W-16P-4XE—ExtremeXOS 31.3 and
later.
ExtremeSwitching
5420F-24P-4XE—ExtremeXOS 31.3 and
later.
ExtremeSwitching
5420F-16MW-32P-4XE—ExtremeXOS 31.3 and
later.
ExtremeSwitching
5420F-16W-32P-4XE—ExtremeXOS 31.3 and
later.
ExtremeSwitching
5420F-48P-4XE—ExtremeXOS 31.3 and
later.
ExtremeSwitching
5420F-48P-4XL—ExtremeXOS 31.3 and
later.
ExtremeSwitching
5420M-16MW-32P-4YE—ExtremeXOS 31.3 and
later.
ExtremeSwitching
5320-48P-8XE—Switch Engine 31.6 and
later.
ExtremeSwitching
5320-24P-8XE—Switch Engine 31.6 and
later.
ExtremeSwitching
5320-16P-4XE—Switch Engine 31.7 and
later.
ExtremeSwitching
5320-16P-4XE-DC—Switch Engine 31.7 and
later.
4220-12P-4X—Switch Engine 32.7.1 and
later.
4220-24P-4X—Switch Engine 32.7.1 and
later.
4220-48P-4X—Switch Engine 32.7.1 and
later.
4220-4MW-8P-4X—Switch Engine 32.7.1
and later.
4220-4MW-20P-4X—Switch Engine 32.7.1
and later.
4220-8MW-40P-4X—Switch Engine 32.7.1
and later.
PoE++
ExtremeSwitching 5520-24W—ExtremeXOS 31.1 and later.
ExtremeSwitching 5520-48W—ExtremeXOS 31.1 and later.
ExtremeSwitching 5520-12MW-36W—ExtremeXOS 31.1 and later.
ExtremeSwitching 5420F-8W-16P-4XE—ExtremeXOS 31.3 and later.
ExtremeSwitching 5420F-16MW-32P-4XE—ExtremeXOS 31.3 and later.
ExtremeSwitching 5420F-16W-32P-4XE—ExtremeXOS 31.3 and later.
ExtremeSwitching 5420M-24W-4YE—ExtremeXOS 31.3 and later.
ExtremeSwitching 5420M-16MW-32P-4YE—ExtremeXOS 31.3 and later.
ExtremeSwitching 5420M-48W-4YE—ExtremeXOS 31.3 and later.
ExtremeSwitching 5720-24MW—Switch Engine 32.1 and later.
ExtremeSwitching 5720-24MXW—Switch Engine 32.1 and later.
ExtremeSwitching 5720-48MW—Switch Engine 32.1 and later.
ExtremeSwitching 5720-48MXW—Switch Engine 32.1 and later.
