show upm timers
show upm timers
Description
Displays a list of the UPM timers on the system and some of their configuration information.
Syntax Description
Default
N/A.
Usage Guidelines
Use this command to see a list of all UPM timers on a switch. The resulting display shows timer configurations, the associated profile, and flags to indicate the timer status. Flags are defined below:
  • a - active
  • d - disabled
  • p - periodic
This command displays UPM timer configuration:
show upm timers
The output of this command is similar to the following:
* BD-8808.43 # show upm timers
Current Time: 2006-10-16 14:03:55
UPM Profile Flags Next Execution
Timer Name time
t1 p1 ep 2006-10-16 14:04:00(Every 10 secs)
timerA
Flags: e - Profile is enabled, d: Profile is disabled
o -Timer is non-periodic, p - Timer is periodic
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.2.1 Licensing Guide document.
