unconfigure igmp ssm-map
unconfigure igmp ssm-map {{vr} vr-name}
Description
Unconfigures all SSM mappings on the virtual router.
Syntax Description
vr-name Specifies a virtual router name. If the VR name is omitted, the switch uses the VR specified by the current CLI VR context.
Default
N/A.
Usage Guidelines
None.
The following command deletes all IGMP-SSM mappings on the virtual router "xyz":
unconfigure igmp ssm-map vr xyz
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.2.1 Licensing Guide document.
