| vman-name | Specifies a VMAN name using up to 32 characters. |
| vman_list | Specifies the VMAN tag range or VMAN Tag List (Ex: 2-4 or 2,3). |
| learning-domain | Specifies that this VMAN is a learning domain, which supports inter-VMAN forwarding. |
| vr | Specifies a virtual router. |
| vr_name | Specifies a virtual router
name. Note: User-created VRs are supported
only on the platforms listed for this feature in the Switch Engine v33.2.1 Licensing Guide
document. On switches
that do not support user-created VRs, all VLANs are created in
VR-Default and cannot
be moved.
N/A.
For information on VMAN name requirements and a list of reserved keywords, see Object Names. You must use mutually exclusive names for:
The keyword learning-domain enables you to create a VMAN that serves as a learning domain for inter-VMAN forwarding.
If you do not specify the virtual router, the VMAN is created in the current virtual router. After you create the VMAN, you must configure the VMAN tag and add the ports that you want.
The following example creates a VMAN named "fred":
create vman fred
This command was first available in ExtremeXOS 11.0.
The vman_list variable was added in ExtremeXOS 16.1.
