configure pim crp static
configure pim {ipv4 | ipv6} crp static ip_address [none | policy] {priority [0-255]}
Description
Configures a rendezvous point and its associated groups statically, for PIM sparse mode operation.
Syntax Description
ipv4 Specifies an IPv4 address.
ipv6 Specifies an IPv6 address.
ip_address Specifies a static CRP address.
none Deletes the static rendezvous point.
policy Specifies a policy file name.
priority Specifies a priority setting. The range is 0–255.
Default
The default setting for priority is 192. Priority value 0 indicates the highest priority.
Usage Guidelines
In PIM-SM, the router sends a join message to the rendezvous point (RP). The RP is a central multicast router that is responsible for receiving and distributing multicast packets. If you use a static RP, all switches in your network must be configured with the same RP address for the same group (range).
ExtremeXOS switches support up to 64 static RPs (32 IPv4 and 32 IPv6), and up to 180 groups (group/mask entries) in a single RP policy file. If you configure more than 180 group entries in a single RP policy file, the switch will not process entries added after the first 180.
The policy file contains a list of multicast group addresses served by this RP.
This policy file is not used for filtering purposes. As used with this command, the policy file is just a container for a list of addresses. So a typical policy file used for RP configuration looks a little different from a policy used for other purposes.
If routers have different group-to-RP mappings, due to misconfiguration of the static RP (or any other reason), traffic is disrupted.
The following example statically configures an RP and its associated groups defined in policy file rp-list:
configure pim crp static 10.0.3.1 rp-list
The following is a sample policy file:
entry extreme1 {
if match any {  }
then { nlri  224.0.0.0/4 ;
nlri  239.255.0.0/24 ;
nlri  232.0.0.0/8 ;
nlri  238.1.0.0/16 ;
nlri  232.232.0.0/20 ;
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.2.1 Licensing Guide document.
