This command configures PoE port-level classification
power-up mode for Extreme Networks PoE devices that do not support 802.3bt when
connecting to switches with 60W/90W PoE ports. ExtremeSwitching platforms
support per-port basis configuration.
Syntax Description
classification
Classification power-up mode.
802.3af
IEEE 802.3af 15W mode.
802.3af-high
IEEE 802.3af 30W mode.
802.3pre-at
IEEE 802.3 pre-at 30W mode.
802.3at
IEEE 802.3at 30W mode.
802.3pre-bt
IEEE 802.3 pre-bt 4-pair 60W mode.
802.3bt-type3
IEEE 802.3bt Type 3 60W mode.
802.3bt-type4
IEEE 802.3bt Type 4 90W mode.
ports
Specifies the port.
port_list
Port list separated by a comma or - .
Default
Depends on the maximum classification level supported by the platform. For
example, one switch can have a default classification level of 802.3bt-type4, while
another a default classification level of 802.3at.
Usage Guidelines
Use the specified power-up classification instead of the default classification based
on port type.
The following command displays all classification options:
