show bgp
show bgp
Description
Displays BGP configuration information.
Syntax Description
Default
N/A.
Usage Guidelines
None.
The following command examples display various BGP configurations:
Output for show bgp for a VRF (PE-CE Protocol, RD and RT configured):
(virtual-router vrf-foo) # show bgp
Enabled             : No                OperStatus          :        Down
RouterId            : 3.3.3.3           AS                  : 200
LocalPref           : 100               MED                 : None
Always-Compare-MED  : Disabled          Aggregation         : Disabled
Route Reflector     : No                RR ClusterId        : 0
IGP Synchronization : Disabled          New Community Format: Disabled
Routes from EBGP    : 2                 Routes from IBGP    : 0
Routes redistributed: 1                 Out Updates queued  : 0
Fast Ext Fallover   : Disabled          MPLS LSP as Next-Hop: No
AS Disp Format      : Asplain           Maximum ECMP Paths  : 1
ConfedId            : 0                 Multipath-Relax     : Disabled
Confed Peers        :
Networks            : 2
  ipv4-unicast 10.0.0.0/16 network-policy nwk.pol
  ipv4-multicast 11.0.0.0/16 network-policy nwk.pol
Aggregate Networks  : 2
  ipv4-unicast 21.0.0.0/8 as-match advertise-policy: agg.pol
  ipv4-multicast 22.0.0.0/8 as-set summary-only advertise-policy: agg.pol
Route Statistics:
Address family         EBGP   IBGP  Redist.
ipv4-unicast           0      0     0
ipv4-multicast         0      0     0
Redistribute        :
Address Family
    Route Type      Flags        Priority      Policy
ipv4-unicast
    Direct          EO           2048          None
ipv6-multicast
    Direct          EO           2048          None
Flags: (E) Export Enabled, (L) Export Operationally Off due to Low Memory,
       (O) Export Operationally On
  Advertise Inactive Routes:
  ipv4-unicast   : Disabled
  ipv4-multicast : Disabled
  ipv6-unicast   : Disabled
  ipv6-multicast : Disabled
  ipv4-vxlan     : Disabled
Output of show bgp for a VRF (PE-CE Protocol, RD and RT “not” configured):
# show bgp
ConfedId            : 0                 Outbound rt. filter : Enabled
Confed Peers        :
Networks            : 4
  ipv6-unicast 2001::/64 network-pol nwk6.pol
  ipv6-multicast 2001::/64 network-pol nwk6.pol
Aggregate Networks  : 4
  ipv6-unicast 2003::/64 as-match advertise-policy: agg6.pol
  ipv6-multicast 2004::/64 as-set advertise-policy: agg6.pol
Route Statistics:
  ipv4-unicast           0      0      0
  ipv6-unicast           0      0      0
  ipv6-multicast         0      0      0
Redistribute:
Address Family
ipv4-unicast
    Direct          EO           2048          None
ipv6-multicast
    Direct          EO           2048          None
If BGP is added as a protocol inside a heavy-weight VR, normal BGP peering applies with the addition of vpnv4 address family support:
# show bgp
Confed Peers        :
Networks            : 4
        nwk6.pol
Route Statistics:
  ipv4-unicast           0      0      0
  vpnv4                  0      0      0
  ipv6-unicast           0      0      0
Redistribute:
  ipv4       Admin     Operational  Shutdown  Policy
  unicast    Status    Status       Priority
  Direct     Disabled  Down         2048      None
  Static     Disabled  Down         2048      None
  RIP        Disabled  Down         2048      None
  BlackHole  Disabled  Down         2048      None
  OSPFIntra  Disabled  Down         2048      None
  OSPFInter  Disabled  Down         2048      None
  OSPFExt1   Disabled  Down         2048      None
  OSPFExt2   Disabled  Down         2048      None
  ISISL1     Disabled  Down         2048      None
  ISISL2     Disabled  Down         2048      None
  ISISL1Ext  Disabled  Down         2048      None
  ISISL2Ext  Disabled  Down         2048      None
  multicast  Status    Status       Priority
  ipv6           Admin     Operational  Shutdown  Policy
  Ripng          Disabled  Down         2048      None
  Ospfv3-intra   Disabled  Down         2048      None
  Ospfv3-inter   Disabled  Down         2048      None
  Ospfv3-extern1 Disabled  Down         2048      None
  Ospfv3-extern2 Disabled  Down         2048      None
This command was modified in Extreme ExtremeXOS 15.3 to reflect its operation in VRs and VRFs.
Support for IPv4 VXLAN was added in ExtremeXOS 22.3.
Support for BGP multipath-relax was added in ExtremeXOS 22.3.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.2.1 Licensing Guide document.
