Displays the current RADIUS client configuration and statistics.
| mgmt-access | Specifies configuration and statistics for the switch management RADIUS authentication server. |
| netlogin | Specifies configuration and statistics for the network login RADIUS authentication server. |
| primary | Primary server. |
| secondary | Secondary server. |
| index | RADIUS server index. |
N/A.
If you do not specify a keyword, configuration details related to both management and network login are displayed. The output from this command displays the status of RADIUS and RADIUS accounting (enabled or disabled) and the primary and secondary servers for RADIUS and RADIUS accounting.
Use the mgmt-access keyword to display only RADIUS configuration details related to management access.
Use the netlogin keyword to only RADIUS configuration details related to network login.
The following sample output displays the current RADIUS client configuration and statistics for both management and network login:
# show radius
RADIUS Default State: enabled
RADIUS Default Timeout: 3 seconds
RADIUS Algorithm: standard
RADIUS Retries: 3
RADIUS port bounce: off
RADIUS dynamic-authorization: enabled
RADIUS TLS TCP Timeout: default
RADIUS TLS OCSP: on
Switch Management RADIUS: disabled
Switch Management RADIUS server connect time out: 3 seconds *
Switch Management RADIUS Accounting: disabled *
Switch Management RADIUS Accounting server connect time out: 3 seconds
Netlogin RADIUS: enabled
Netlogin RADIUS server connect time out: 3 seconds *
Netlogin RADIUS Accounting: disabled *
Netlogin RADIUS Accounting server connect time out: 3 seconds
RADIUS server : 1 Status is Active
host name :
IP address : 10.51.1.150
Server IP Port: 1812
Protocol : UDP
Client address: 10.68.5.4 (VR-Mgmt)
Retries : 3 *
Timeout : 3 *
Realm : Netlogin
shared secret : #$Qzamzk1OwQoU9jmTyFiEH1qT+Hp6+g==
Access Requests : 2 Access Accepts : 2
Access Rejects : 0 Access Challenges : 0
Access Retransmits: 0 Client timeouts : 0
Bad authenticators: 0 Unknown types : 0
Round Trip Time : 221
RADIUS DynAuth server: 1 Status is Active
host name :
Server IP Port: 3799
Protocol : UDP
shared secret : #$Mpu4FUpTNAtZ2cQAM/xAQI92SpD9vw==
NAS-IP : Require
CoA Requests : 11 Disc Requests : 5
CoA Accepts : 2 Disc Accepts : 3
CoA Rejects : 7 Disc Rejects : 1
CoA Dup Requests : 0 Disc Dup Requests : 0
CoA Bad Auths : 0 Disc Bad Auths : 0
CoA Packet Drops : 2 Disc Packet Drops : 1
The following command displays RADIUS TLS OCSP attributes (lines 9-12):
# show radius
RADIUS Retries: 3
RADIUS dynamic-authorization: disabled
RADIUS TLS OCSP: on
RADIUS TLS OCSP Attributes:
Nonce : on
Signer ocsp-nocheck : on
Override Server URL : http://radiusocsp:2021
Primary Netlogin RADIUS server: Status is Active
host name :
IP address : 10.127.6.195
Protocol : UDP
Client address: 10.127.6.85 (VR-Mgmt)
Retries : 3 *
Timeout : 3 *
shared secret : #$1HkCDc0zAm64sGwES6xVTN91clZEXQ==
Access Requests : 655 Access Accepts : 655
Round Trip Time : 0
Legend: An asterisk (*) indicates a global value is in use.
# show radius
RADIUS Default State: disabled
RADIUS Retries: 3
RADIUS port bounce VSA: off
RADIUS TLS OCSP: off
Nonce : off
Signer ocsp-nocheck : off
Override Server URL : none
Switch Management RADIUS: disabled *
Netlogin RADIUS server keep alive: on
Netlogin RADIUS server keep alive interval: 60 seconds
Netlogin RADIUS server's last known reachability status: unreachable
host name :
IP address : 1.2.3.4
Protocol : UDP
Client address: 10.127.2.33 (VR-Mgmt)
Retries : 3 *
Timeout : 3 *
shared secret : #$S4/Mj804b1yid8IYgRCNF2qdlGKD+A==
Access Requests : 157 Access Accepts : 0
Access Retransmits: 117 Client timeouts : 156
Round Trip Time : 0
The mgmt-access and netlogin keywords were added in ExtremeXOS 11.2.
The primary and secondary keywords, and index variable were added in ExtremeXOS 16.1.
This command was updated to show dynamic authorization status in ExtremeXOS 22.1.
This command was updated to show counters for dynamic authorization in ExtremeXOS 31.4.
RADIUS TLS OCSP attributes were added in ExtremeXOS 32.2.
This command was updated to show RADIUS port bounce in version 32.5.
