show ip nat vlan
show ip nat vlan {vlan_name}
Description
Shows Network Address Translation (NAT) VLAN information.
Syntax Description
ip Shows Internet Protocol (IP) information.
nat Shows NAT information.
vlan Specifies VLAN NAT information.
vlan_name Specifies which VLAN to show NAT information for.
Default
N/A.
Usage Guidelines
To view information for a specific VLAN, specify the VLAN name when running this command.
The following example shows VLAN NAT information:
# show ip nat vlan
VLAN Name                         Direction
engineering                       Both
in                                Ingress
out                               Egress
Total Number of NAT VLANs   : 3
Maximum number of NAT VLANs : 4
This command was first available in ExtremeXOS 31.2.
Platform Availability
This command is available on the switches that support the IP NAT feature. For information about which switches support this and other features, see the Switch Engine v33.2.1 Licensing Guide document.
