show ripng interface
show ripng interface {detail | vlan vlan-name | tunnel tunnel-name}
Description
Displays RIPng-specific configuration and statistics for the specified interface.
Syntax Description
detail Specifies detailed display.
vlan-name Specifies an IPv6 configured VLAN.
tunnel-name Specifies an IPv6 tunnel.
Default
Show summary output for all interfaces.
Usage Guidelines
Displays the RIPng interface configuration and runtime information. If no interface is specified, only the summary data for all the configured interfaces is displayed. If an interface is specified, only the data for that interface is displayed in detail. If the keyword detail is specified, detailed data for all interfaces is displayed.
The following command displays the RIPng configuration summary for all interfaces:
The following is sample output from this command:
VLAN       IP Address         Flags    Sent     Rcvd     Triggered Cost
                                       Packets  Packets  Updates
v1         22cc::3        /64  rif-pst  106349   106349   3         15
v2         22bb::1        /64  rif-pst  106349   106095   3         1
v3         2abc::1        /120 rif-pst  106351   0        4         1
v4         3ffe::1        /64  rif-pst  106349   139124   3         1
Flags: (f) Interface Forwarding Enabled, (i) Interface RIPng Enabled
       (n) Multinetted Interface, (r) Router RIPng Enabled
       (p) Poison Reverse Enabled, (s) Split Horizon Enabled
       (t) Trigerred Update Enabled.
The following command displays RIPng-specific statistics for the VLAN v1:
show ripng interface v1
VLAN                : v1                 Interface           : 22cc::3/64
Router RIPng        : Enabled            Cost                : 15
Input Policy        : None               Output Policy       : None
Trusted GW Policy   : gw6                Poison Reverse      : Enabled
Split Horizon       : Enabled            Triggered Updates   : Enabled
Rcved Packets       : 106358             Sent Packets        : 106358
Sent Trig. Updates  : 3                  Rcved Bad Packets   : 0
Rcved Bad Routes    : 0
Neighbor Addresses  : fe80::201:30ff:fe94:f400
Interface Addresses : 22cc::3/64, fe80::280:c8ff:feb9:2855/64
Platform Availability
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.2.1 Licensing Guide document.
