configure pim register-policy
configure pim {ipv4 | ipv6} register-policy [rp_policy_name | none]
Description
Configures the register filter at the First Hop Router (FHR). This is the router to which the multicast source is connected to.
Syntax Description
ipv4 Specifies the IPv4 address family.
ipv6 Specifies the IPv6 address family.
rp_policy_name Specifies the Policy File for Register filter.
none Unconfigures the configured FHR Register filter.
Default
IPv4.
Usage Guidelines
Use this command to add or remove a First Hop Router Register Filter policy.
The following example configures an IPv4 register policy named "entry_policy" at the FHR:
configure pim ipv4 register-policy entry_policy
This command was first available in ExtremeXOS 15.3.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.2.1 Licensing Guide document.
