disable bootprelay ipv6
disable bootprelay { ipv4 | ipv6} {vlan vlan_name} | { vr vr_name} | all {vr vr_name}
Description
Disables BOOTPRelay v6. This can be done across the VR or on a per VLAN basis.
Syntax Description
bootprelay BOOTP Relay service.
IPv4 DHCPv4 BOOTP Relay service.
IPv6 DHCPv6 BOOTP Relay service.
vlan_name Specifies the VLAN name
vr_name Specifies the vrtual router name.
all Disables all VLANs.
Default
N/A.
Usage Guidelines
Use this command to disable BOOTP Relay across the VR or on a per VLAN basis.
The following command displays IPv6 bootprelay information:
* switch # show bootprelay ipv6
BOOTP Relay: DHCPv6 BOOTP Relay enabled on virtual router "VR-Default"
Include Secondary : Disabled
    BOOTP Relay Servers :2001::1
                         3001::1
                         4001::1
VLAN "Default"         :
    BOOTP Relay        : Enabled
    Interface ID       : 3999 (Default)
    Remote ID          : 00:04:96:52:08:76 (Default)
    Prefix Snooping    : Disabled
VLAN "v1"              :
    Interface ID       : Interface-Sring1
    Remote ID          :
* switch #
This command was first available in ExtremeXOS 15.5.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.2.1 Licensing Guide document.
