Enables MLD SSM mapping on a virtual router (VR).
| vr vr_name | Specifies a virtual router name. |
Disabled.
Use this command to enable MLD SSM mapping on a VR.
Configure the SSM address range using the configure pim ipv6 ssm range [default | {policy} policy_name] command before you enable SSM Mapping.
The following example enables SSM mapping on VR1:
enable mld ssm-map vr vr1
This command was first available in ExtremeXOS 15.5.
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.2.1 Licensing Guide document.
