show mcast ipv6 cache
show mcast ipv6 cache {{vlan} name} {{[group v6GrpAddressMask | v6GrpAddressMask] {source v6SourceIP | v6SourceIP}} {type [snooping | pim]} {with-in-port} | {summary}}
Description
Displays multicast cache information. The display can be limited to entries for specific VLANs or groups, and it can be limited to specific types of entries, such as those created by snooping protocols, or PIM.
Syntax Description
name Specifies a VLAN name.
v6GrpAddressMask Specifies a multicast group address and mask.
v6SourceIP Specifies the source IP address for a multicast group.
snooping Limits the display to cache entries created by MLD snooping.
pim Limits the display to cache entries created by PIM.
summary Specifies the summary display format.
Default
Displays information for all entries in the multicast cache.
Usage Guidelines
None.
The following command displays all multicast cache information:
# show mcast ipv6 cache
Snooping Cache Timeout: 300 sec
(ff03::1  3001::1)
Type: snoop Age: 9 Ingress Vlan: v1
Vlan             Port        Vid
v1               25          4084
(ff03::1  3001::2)
Vlan             Port        Vid
v1               25          4084
Multicast cache distribution:
2 entries from Snooping           0 entries from PIM
Total Cache Entries: 2
The following command displays summary cache information for VLAN v1:
# show mcast ipv6 cache vlan v1 summary
==============MULTICAST CACHE SUMMARY==============
v1: Multicast cache distribution:
Total Cache Entries for VLAN v1: 2
This command was first available in ExtremeXOS 15.2.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MLD snooping feature, see the Switch Engine v33.2.1 Licensing Guide document.
