enable ripng splithorizon
enable ripng splithorizon {vlan vlan-name | tunnel tunnel_name | [vlan | tunnel] all}
Description
Enables the split horizon algorithm for RIPng.
Syntax Description
vlan-name Specifies an IPv6 configured VLAN.
tunnel_name Specifies an IPv6 tunnel.
all Specifies all interfaces.
Default
Enabled.
Usage Guidelines
Split horizon is a scheme for avoiding problems caused by including routes in updates sent to the router from which the route was learned. Split horizon omits routes learned from a neighbor in updates sent to that neighbor.
The following command enables the split horizon algorithm for RIPng on all IPv6 configured interfaces:
Platform Availability
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.2.1 Licensing Guide document.
